Command |
Path |
DMX Controls |
DMX |
When a lighting console is connected, you can use DMX to control camera views, ambient lighting, and haze direction. Up to nine saved camera views are available from the console. These virtual views are set up and stored within the .v3s file, and they must be patched into an available universe. The DMX information follows the Last Takes Precedence (LTP) priority; the latest information sent takes priority.
The DMX patch information is saved along with the camera views in the .v3s file.
To use DMX for the Vision view:
Select the command.
The Setup DMX Controls dialog box opens.
To activate and control the camera views, select the check box for the camera to use and specify its Universe and Channel number. There are 11 channels per DMX camera.
Channel |
Coarse/Fine |
Purpose |
%: Function |
1 |
Activation |
● 0–49: Deactivate Camera ● 50–100: Activate Camera |
2
Coarse |
Pan Horiz |
● 0–0: No pan ● 1–48: Pan left ● 49–51: No pan ● 52–99: Pan Right ● 100–100: No pan |
3 |
Fine |
4
Coarse |
Pan Vert |
● 0–0: No pan ● 1–48: Pan down ● 49–51: No pan ● 52–99: Pan up ● 100–100: No pan |
5 |
Fine |
6
Coarse |
Orbit Horiz |
● 0–0: No orbit ● 1–48: Orbit left ● 49–51: No orbit ● 52–99: Orbit right ● 100–100: No orbit |
7 |
Fine |
8
Coarse |
Orbit Vert |
● 0–0: No orbit ● 1–48: Orbit up ● 49–51: No orbit ● 52–99: Orbit down ● 100–100: No orbit |
9
Fine |
10
Coarse |
Zoom |
● 0–0: No zoom ● 1–48: Zoom in ● 49–51: No zoom ● 52–99: Zoom out ● 100–100: No zoom |
11
Fine |
The view within the viewport changes to that of the selected camera.
To control the ambient intensity, select the check box for this effect and specify its Universe and Channel number.
Channel |
Coarse/Fine |
Purpose |
%: Function |
1 |
Ambient |
● 0–0: No ambient ● 1–100: Ambient value |
To control the speed of the haze texture image as it moves in vertical and horizontal directions, select the check box for the haze direction and specify its Universe and Channel number.
Channel |
Coarse/Fine |
Purpose |
%: Function |
1
Coarse |
Haze Vertical Speed |
● 0–0: No direction ● 1–48: Haze left ● 49–51: No direction ● 52–99: Haze right ● 100–100: No direction |
2 |
Fine |
Channel |
Coarse/Fine |
Purpose |
%: Function |
1
Coarse |
Haze Horizontal Speed |
2 |
Fine |
