Tool |
Tool set |
Insert Truss
Rigging |
The Insert Truss tool places a section of truss on the drawing; depending on the resource selected, the truss may be straight, curved (or circular), or a corner element, and it may be horizontal or vertical. In Auto Connect mode, a truss connects to existing trusses, forming a truss system. When Auto Connect mode is disabled, the truss is not connected to an existing truss.
The following modes are available.
Mode |
Description |
Auto Connect |
When enabled, connects the inserted truss to the current truss system with geometrical precision; also generates a preview of connected trusses that are being moved |
Truss symbol |
Select the truss to insert |
Hanging Angle |
Specifies the hanging angle from the X axis |
Maintain class of symbol |
Uses the class specification from the symbol definition; disable the mode to insert the truss into the active class instead |
To insert a truss symbol:
Click the tool. Click Truss symbol on the Tool bar. From the Resource Selector, double-click a resource to activate it.
If a symbol is not selected, the Select Symbol dialog box opens automatically to select one.
Alternatively, from the Resource Manager, either double-click the truss symbol to insert or right-click on the truss symbol and select Make Active from the context menu. The Insert Truss tool is automatically selected.
If a truss symbol is accidentally inserted by the Symbol Insertion tool, the truss functionality will not be present. When correctly inserted, the Object Info palette displays “Truss” for the selected truss.
If the selected truss has insufficient information for proper calculations, the Truss Properties dialog box opens automatically, to enter required information; see Creating a Custom Truss Symbol.
Truss resources are organized by type, such as horizontal, vertical, curved, corner, and so on. Select the desired type of truss element for insertion.
If this is the first truss placed, click to place the object in the drawing, and click again to set the orientation.
If connecting to an existing truss system, enable Auto Connect mode. When adding a truss to an existing system, a valid existing component to connect to is highlighted, indicating that if placed there, the new component will connect to the system. The Connectable with parameter determines whether structural elements can connect; trusses can only connect to compatible connectors, as described in Concept: Creating a Connected Rigging System. Move the mouse to hover over the connection; depending on the type of truss being attached and the view, various options are previewed for connecting the truss. For example, connecting a three way corner truss will have different insertion options available from connecting a four way truss, and Top/Plan view will provide different previews from 3D insertion. Auto Connect mode automatically flips gable, fork, spigot male/female trusses so that they connect properly.
When inserting a vertical truss, the current view affects the truss insertion. In a 3D view, such as an isometric view, truss sections can to be added to either end of an existing truss, or to an existing corner element. In Top/Plan view, only the end of an existing truss is visible, and truss sections can only be added to the top end of an existing truss.
If no highlighting occurs with Auto Connect mode enabled, the trusses are not connectable.
When the desired location and orientation is highlighted, click to place the truss.
The truss properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
