Drawing slabs manually|
Mode |
Tool |
Tool set |
Modes for the Polyline tool
Slab
Building Shell |
To draw a manual slab object that is not associated with any walls:
1. Click the tool and the Polyline mode.
A slab can also be created by drawing a polyline and then selecting the Create Objects from Shapes command (see Creating objects from shapes).
2. Do one of the following:
● To use an existing slab style from the resource libraries, click Slab Style from the Tool bar. From the Resource Selector, double-click a resource to activate it. Alternatively, to draw an unstyled slab, leave the <Unstyled> setting as is. Proceed to step 3.
● To create a custom slab style, click Preferences. From the Slab Preferences dialog box, set the default properties (see Creating slab styles). The properties can be edited from the Object Info palette.
3. Similarly to drawing a polygon, create a closed slab shape.
Double-click while drawing to close the slab automatically.
