Command |
Path |
Create Schematic View |
Spotlight > Visualization |
Use the Create Schematic View command to generate interactive plans of rigging and any attached loads. You can create the schematics before or after you have finished designing in 3D. The schematic views are linked with the model, so applicable edits are transferred between the model objects and their schematic instances; see Concept: Schematic views.
To create a schematic view:
1. Select one or more rigging objects, and select the command.
The Create Schematic View dialog box opens.
2. Set the desired options.
A schematic view is created for each rigging object and its associated loads. The schematic views are inserted at the document origin. If multiple schematics were created, they are inserted next to each other based on the stacking order of the parent rigging objects. All schematic objects are inserted in the active class.
Within the schematic view, lighting devices and other load objects can be added, removed, and repositioned; see Managing loads for more information.
