Spot00006.pngManaging loads
The Manage Loads tool is in the Rigging tool set.
The Manage Loads tool allows you to associate, reposition, and disassociate load objects from rigging objects—in the model and in schematic views. In the model, the tool can also be activated by selecting Manage Loads from a rigging object’s context menu. Managing loads with the tool is unaffected by the auto positioning options in Spotlight preferences setup; whether auto positioning is enabled or disabled, the Manage Loads tool can be still used to associate and reposition loads, such as lighting devices, speakers, and soft goods. See Associating loads with rigging objects.
When repositioning a load on a truss line, the tool’s Reposition mode enables sophisticated truss snapping. This allows you to precisely set the load’s hanging point on the top, bottom, or side of the truss. Using the tool for repositioning is more precise than Associating existing loads by dragging.
The following modes are available:
Mode
Description
Attach
Associates selected load objects with the selected rigging object
Remove
Disassociates selected load objects from their associated rigging object
Reposition
Displays control points on all load objects associated with a selecting rigging object, for repositioning the loads.
To display control points on schematic loads, select the schematic load or its associated schematic rigging object.
There are several ways to associate lighting devices and other loads with a rigging object. The association can be automatically created when the load is created or when an existing load is moved in the drawing. For details, see Associating loads with rigging objects. In addition, various commands allow you to associate, move, and disassociate loads from rigging objects in the model and in schematic views.
Action
Method
Description
Associating Loads
Insert a load on a rigging object
Symbol insertion
Spotlight preferences: Loads and rigging pane and Adding lighting instruments
Move a load to a rigging object
Click-drag operation
Attach one or more loads to a rigging object
        Manage Loads tool
        Load object context menu command
Associating existing loads with the Manage Loads tool
Repositioning Associated Loads
Move a load’s hanging point in the model and schematic view
        Manage Loads tool (model only)
        Hanging point control point
        Repositioning loads with the Manage Loads tool
        Moving schematic loads by control points
Move a load’s offset position in the schematic view
Object position control point (schematic only)
Move an offset load onto the schematic rigging object
Drop-down context menu command (schematic only)
Moving an offset load onto the schematic rigging object
Move all offset loads onto the schematic rigging object
Rigging object context menu command (schematic only)
Moving all offset loads onto the schematic rigging object
Disassociating Loads
Disassociate a load from the rigging object
Manage Loads tool
Disassociating loads with the Manage Loads tool
Remove a load from the schematic view
Disassociating loads in the schematic view
Concept: Rigging objects
Concept: Schematic views
Repositioning loads
