Spot00050.pngSpotlight preferences: Loads and rigging pane
Command
Path
Spotlight Preferences
File > Document Settings
The Loads and rigging pane of the Spotlight Preferences dialog box controls automatic positioning and automatic classing options for trusses and loads and enables truss coloring.
Lighting instruments and other loads can be automatically associated with a rigging object, both at insertion and when an existing load is moved on the light plot. Throughout the design work, particularly in the later stages, instruments may need to be moved slightly, but they should not be accidentally associated with a different nearby rigging object. Auto positioning provides the necessary control over the automatic association of load objects with rigging objects. See Concept: Rigging objects for more information.
To assign classes and preferences for trusses and other rigging objects:
1.      Select the command.
2.      The Spotlight Preferences dialog box opens. Click the Loads and rigging pane.
Spotlight preferences setup
Spotlight preferences: Lighting devices: Parameters pane
Spotlight preferences: Lighting devices: Class and color pane
Spotlight preferences: Universes pane
Spotlight preferences: Lightwright pane
