Spot00053.pngSpotlight preferences: Lighting devices: Parameters pane
Command
Path
Spotlight Preferences
File > Document Settings
You can enter global orientation settings for lighting instruments on insertion, and set default display parameters for the label legend. This pane also specifies which lighting device parameters display on the Shape tab of the Object Info palette.
To assign lighting device preferences:
1.      Select the command.
2.      The Spotlight Preferences dialog box opens. Click the Lighting devices: Parameters pane.
Lighting device properties
Concept: Record formats, reports, and schedules
Spotlight preferences setup
Spotlight preferences: Loads and rigging pane
Spotlight preferences: Lighting devices: Class and color pane
Spotlight preferences: Universes pane
Spotlight preferences: Lightwright pane
