Spot00058.pngSpotlight preferences: Universes pane
Command
Path
Spotlight Preferences
File > Document Settings
The Universes pane determines the address values for each universe, and manages the universes in each system.
As lighting devices are added to the light plot with automatic numbering (see Numbering light plot objects), the instrument's Absolute Address, Universe/Address, Universe, and DMX Address parameters can be set; they can be edited from the Object Info palette. Patching adjustments may update these values; see DMX patching.
To set up universe address values:
1.      Select the command.
2.      The Spotlight Preferences dialog box opens. Click the Universes pane.
Lighting device properties
Spotlight preferences setup
Spotlight preferences: Loads and rigging pane
Spotlight preferences: Lighting devices: Parameters pane
Spotlight preferences: Lighting devices: Class and color pane
Spotlight preferences: Lightwright pane
