Lighting design
Vectorworks Spotlight provides the lighting designer with all the tools necessary to plan and create a light plot and its associated paperwork. See Lighting for more information about lighting design within a larger event design workflow.
Spot.pngConcept: Vectorworks Spotlight terminology
In the Vectorworks Spotlight program, you use the Lighting Instrument tool to place a lighting instrument on the drawing. Optionally, you can use the Lighting Accessory tool to place a lighting accessory on the drawing, and associate it with the appropriate instrument. Because they are so closely linked, all instrument and accessory objects are referred to as “lighting devices” when they are edited from the Object Info palette, Properties dialog box, or Lighting Device dialog box. The Device Type field indicates whether an accessory or instrument is being edited. A lighting accessory has a type of Accessory or Static Accessory; any other Device Type indicates a lighting instrument.
Lighting devices and other loads can be associated with hanging positions and rigging objects, which include trusses, lighting pipes, lighting pipe ladders, and the rigging geometry within hanging position objects. The point where a load attaches to a rigging object is the load’s hanging point. This is the point where Braceworks calculates the load (Braceworks required). Moving the load’s hanging point moves the load’s actual position on the rigging object.
Workflow: Designing events
Event rigging and structural analysis
Workflow: Pre-rigging the event
Light plot structure
Concept: Rigging objects
Concept: Hanging positions
Inserting hanging positions
Setting up instrument label legends
Adding lighting instruments
Managing loads
Inserting multi-circuit instruments
Editing lighting instruments
Adding accessories
Instrument and accessory specifications
Ganging instruments
Focusing instruments
Obtaining photometric data
Lighting symbol maintenance
Creating instrument summaries
Numbering light plot objects
Generating paperwork
Spotlight preferences setup
