The tools from the Detailing tool set refine the detail drawing with either 2D or 3D detail objects. These tools can significantly reduce the amount of time necessary to make an accurate representation of an object. Detailing tool objects can be used in conjunction with other objects, such as groups, symbols, rectangles, and polylines. The following illustration shows several examples of each, used in conjunction to create a fully-developed detail form.
