DesignSeries00035.pngEditing a Database Callout
    To change the note text, either double-click the callout with the Selection tool, or select the callout and click Edit Note from the Object Info palette. The Notes Manager: Callout dialog box opens. Select a different note as described in Placing Database Callouts, and click OK.
    Edit the database callout parameters from the Object Info palette as for an ordinary callout. See Inserting Callouts or Keynotes.
    Edit the graphics of a database callout as for an ordinary callout; see Editing the Callout Graphic.
    To convert an existing database callout into an ordinary callout, click Edit Note from the Object Info palette, and then click Hide Database Controls. The callout text can then be edited, and the database text is not affected.
    If there are several callout objects, use the Align/Distribute Leader Lines command to improve readability (see Aligning and Distributing Leader Lines).
Notes Management with Databases
Notes Management
vectorworks.net
