When you create a section viewport, you can place it on either a sheet layer or design layer. Section viewports on design layers are useful when a detailed section is needed, or when the section viewport needs to be referenced into other files.
If you want to use annotations and automatic drawing coordination of the sheet and drawing numbers, or if you need multiple viewports on a sheet layer with different views and scales, create the viewport on a sheet layer instead. (See Creating a Section Viewport on a Sheet Layer.)
Create a section view from a design layer, from a clip cube, or from a viewport on a sheet layer. A section viewport that is created from a design layer or clip cube can be updated when changes are made to the design layer. However, a section viewport that is created from a viewport does not maintain a connection to the viewport that created it. It updates when the design layers that are visible in the source viewport change.
To create a section viewport on a design layer:
Prepare to create the viewport as follows:
● To create a section view from an active design layer, set the layer to Top/Plan view by selecting View > Standard Views > Top/Plan.
● To create a section view from an existing viewport, select a non-sectioned viewport object. The viewport object must be in Top, Bottom, Left, Right, Front, or Back view orientation.
● To create a section view from an existing clip cube object, use the Selection tool to highlight the face of the clip cube where the section will begin. (See Viewing a Model with the Clip Cube.) Right-click (Windows) or Ctrl-click (Mac) to open the context menu.
Select View > Create Section Viewport (for a design layer or viewport), or select Create Section Viewport from the context menu (for a clip cube).
Draw the section line to create the cutting plane on the design layer or viewport. For a clip cube, skip to step 4; the section line is created automatically from a vertical clip cube face, and no section line is created from a horizontal face.
Click in the drawing and drag the mouse to begin drawing the marker line. Click to mark the end of the line, and then click to indicate the side of the line to look toward (keep), which is indicated by a black arrow. Double-click to end the line.
To create a broken section line, click in the drawing and draw the first segment. Indicate which side of the drawing to show in the viewport. Click and drag to draw additional segments; broken section line segments are always parallel or perpendicular to each other. Double-click to end the broken line.
The Create Section Viewport dialog box opens. After you select the design layer on which to create the viewport, several parameters that apply only to section viewports on sheet layers become unavailable; they are not included in the parameters table. Enter the desired parameters.
The scale of a design layer section viewport is the same as the layer where it is placed. The rendering mode of the current layer is also used to render the design layer section viewport.
Click OK. A section line object is created in the design layer (unless you used a horizontal face of a clip cube), or is added to the annotations of the existing non-sectioned viewport. A section viewport is created on the selected design layer, and the drawing switches to that design layer, displaying the new section viewport.
In Top/Plan view, the cross section areas (along the plane where the section was cut) are displayed in red by default. To change the fill color, or to display sectioned objects with their original attributes, change the viewport’s Advanced Properties (see Advanced Section Viewport Properties).
Initially, the view is set to Top/Plan, but this can be changed, and the section can be displayed in any view (the Flyover tool can also be used to view the section). Additionally, there is an option to display a flattened version of the section, which can be used to create section drawings or details.
A design layer section viewport can be cropped, but it does not contain an annotation space.
