Spot00066.pngSetting soft goods 3D display options
Select a texture or color to display on the curtain, border, or pipe-and-drape assembly in 3D views. A curtain object can also be made to look like a scrim; pipe-and-drape assemblies can have alternating panel colors. The Vectorworks Spotlight product includes a number of sample textures, or you can create your own textures (see Creating textures). The settings made here override any class settings made, if the soft goods object is assigned to a class; an alert dialog box opens if there is a conflict.
To set the 3D display options:
Select a curtain, border, or pipe-and-drape assembly. From the Object Info palette, click 3D Curtain Options. The 3D Curtain Options dialog box opens. Select the display option from the 3D Curtain Options list and then choose the formatting options.
Inserting curtains and borders
Inserting pipe-and-drape assemblies
Formatting soft goods object labels
