Placing point of connection objectsTool |
Tool set |
Point of Connection
Irrigation |
The Point of Connection tool places a Point of Connection (POC) object, which represents the source of water for the irrigation system. Normally, there is only one POC for the system. There are two types of POC: service line and custom. A service line has a known and predictable static pressure value. Custom types of POC include pumps and cisterns or other types of water sources.
To place a POC on the drawing:
1. Click the tool, and then click Point of Connection on the Tool bar. From the Resource Selector, double-click a resource to activate it. Select from one of the point of connection libraries, or select a custom resource from Custom POCs.vwx and set its properties after placement.
2. Click Preferences.
The Object Properties dialog box opens. Select the default POC settings. The Point of Connection tool uses these preferences until they are changed again.
Click
to show/hide the parameters.
3. Click once to place the POC. If placing the POC over an existing pipe or irrigation pipe network, the connecting pipe is highlighted and the POC is automatically connected to the network.
Adjust the location of the POC labels by dragging the label control point.
The POC properties can be edited from the Object Info palette. Available parameters depend on the POC type.
Click
