Specialized devices can be placed on the drawing, or placed “in line” on a circuit, dividing the circuit where they are placed. Terminal panels have a special socket that can accept connections from either side.
If an existing jack (jackfield) or terminal panel device is already selected when placing a new device, the new device is sequentially numbered.
To place a specialized device:
1. Click the tool that matches the type of required device from the Schematics tool set.
2. For jack (jackfield) and panel tools, click the Preferences button on the Tool bar to open the Preferences dialog box. By default, the values from the ConnectCAD settings are applied (see Specifying ConnectCAD settings), but they can be overridden here.
Click
to show/hide the parameters.
3. If placing the device over an existing circuit, the circuit is highlighted to indicate that the device will be inserted into the circuit. Click to place the device.
Depending on the tool type, one of the following dialog boxes opens automatically: VDA tool, ADA tool, Jackfield Setup, Term Panel Setup, or Connector Panel Setup. Specify the device parameters.
The Conn Panel Input and Conn Panel Output tools are special panel connector devices that can be associated with a Conn panel on the Rack Elevation layer. See Creating connector panel layouts.
Click
4. Specify the device parameters and labeling options, and click OK to place the device into the circuit or in the drawing.
If you continue placing the same jackfield or terminal panel device, the device number automatically increments.
