Setting document preferences
Command
Path
Document Preferences
File
Document preferences only apply to the current drawing, and they remain in effect until they are changed. The settings can be saved and managed from any tab in the Document Preferences dialog box; see Using saved sets. When a .esc or .mvr file is opened in Vision, the most recent settings are applied.
Document preferences can also be set from The Properties palette.
To change the preference settings in the document:
1.      Select the command.
The Document Preferences dialog box opens.
2.Click each tab to set the preferences. Click Apply to apply the settings while keeping the Document Preferences dialog box open.
Document preferences: General tab
Click the General tab to set various display preferences.
Document preferences: Rendering tab
Click the Rendering tab to set the rendering preferences.
Document preferences: Environment tab
Click the Environment tab to set preferences for the environment lighting.
Document preferences: Haze tab
Click the Haze tab to set the haze preferences.
Document preferences: Bloom tab
Click the Bloom tab to set the bloom preferences.
Document preferences: Heat Map tab
Click the Heat Map tab to set the heat map preferences.
Setting Vision preferences
Editing the scene
DMX transforms
Assigning textures
Saving the scene as an image
Saving the scene as a movie
Using DMX controls
The DMX recorder
