Command |
Path |
Shortcut |
Properties |
Window |
● Ctrl+Shift+Y (Windows) ● Cmd+Shift+Y (Mac) |
From the Properties palette, you can view and edit the parameters of selected fixtures, objects, or layers. The available parameters depend on the items selected. Depending on the parameter, a field may be edited, a value toggled, or a dialog box opened.
You can use the mouse wheel or arrow keys to change numerical parameter values by small increments; for larger increments, use the Page Up/Page Down keys.
To open the Properties palette:
Select the command.
Individual parameters are categorized by function. Click the disclosure arrows to expand the categories. Press the Alt key (Windows) or the Option key (Mac) when clicking a disclosure arrow to expand or collapse all items in that category.
Use the scroll bar on the Properties palette to navigate the list, or scroll with the Page Up/Page Down and arrow keys.
When multiple items are selected, the exact parameter values display only if they are identical for all selected items. When a value differs, this is indicated by a double asterisk (**) after the parameter name, followed by a blank field or a value of 0.00.
A parameter value of “Multiple” may display if one or more multi-part fixtures are selected. “Multiple” indicates that the parameter value is not identical for all parts of the fixture.
When no scene items are currently selected, the global scene parameters display in the Properties palette. To edit these parameters, select ROOT from the Scene Graph palette.
Most, but not all, of the global scene parameters can also be edited from the Document Preferences dialog box. For ease of access, frequently used parameters display at the top of the Globals list in the Properties palette. The remaining global parameters are grouped like the tabs on the Document Preferences dialog box.
Click
to show/hide the parameters.
When scene items are selected, the parameters that display in the Properties palette depend on the type of item. Some parameters are available for both objects and fixtures, while others are available either for objects or for fixtures. Some of these parameters are also available for layers in the Scene Graph palette (for more information on layers, see Organizing the scene contents).
Click
