Tool |
Tool set |
Interior Elevation Marker
Dims/Notes |
The Interior Elevation Marker tool creates an object that serves as a reference graphic for interior elevation viewports, to graphically indicate for which directions the viewports were created.
In Design Series products, interior elevation markers have additional functionality.
● Link an interior elevation marker to existing viewports, for annotation purposes.
● Sync the marker’s drawing titles, drawing numbers, and sheet number with the linked viewports.
● Automatically delete a linked viewport when it’s removed from the marker.
The alignment modes temporarily override the marker’s defined insertion point, for precise placement.
Mode |
Description |
Align Object Left |
Insertion point is the left edge of the marker’s bounding box |
Align Object Center |
Insertion point is the center of the marker’s bounding box |
Align Object Right |
Insertion point is the right edge of the marker’s bounding box |
Align Object Origin |
Insertion point is the marker’s originally specified insertion point |
Style |
Opens the Resource Selector to select an interior elevation marker for placement; double-click a resource to activate it |
Preferences |
Sets the default parameters that are used for each new interior elevation marker object |
To create an interior elevation marker:
1. Click the tool.
2.Do one of the following:
● Click Style on the Tool bar to select a resource from the Resource Selector.
● Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
3.Click to place the object, and click again to set the rotation.
Once a marker is in the drawing, you can edit it from the Object Info palette. The following additional options are available when editing interior elevation markers.
Option |
Description |
Style list options |
● Replace: Applies a different style to this object ● Convert to Unstyled: Allows you to modify the settings and marker layout for this object only ● Edit Style: Allows you to modify the settings and marker layout for all objects in the drawing that use the current style See Creating styles for markers and drawing labels for details. |
Edit Section Lines (Design Series required) |
For a marker linked to viewports, click to enter Object editing mode and edit the section lines that define the viewports; see Modifying section lines graphically |
Navigate to Viewports (Design Series required) |
For a marker linked to viewports, navigates to the Linked Layer and selects the viewports |
Edit Marker Layout (unstyled markers)
Opens an editing window to change the geometry and text in the marker; see Creating styles for markers and drawing labels |
