Spot.pngPreview cable suite
The preview of the cable suite offers a chance to use new functionality that will continue to be developed in future versions. You can ease into the new features without being forced to transition abruptly to the new suite and workflow.
This preview suite of re-engineered cable tools presents an alternative workflow, with more flexibility to work in both 2D and 3D and take advantage of the most current Vectorworks functionality. These objects are compatible with Braceworks, so the cable impacts on a system can be calculated seamlessly and without current workarounds.
For more information about the preview suite, to provide feedback, and to discuss usage with other Vectorworks professionals, navigate to this forum post.
Workflow: Placing cables
Follow the suggested workflow when placing cables.
●       Model the venue space, including all the scene geometry, stage decks, trusses, lighting devices, and other electronic devices that require cables.
●       Select Cable Preferences to define the default parameters of cable objects and optionally, select a cable set.
To use different preference settings in a specific part of the venue, use the Cable Area tool to draw a cable area. For example, cables on trusses may require additional slack than those placed at ground level.
●       Manage the cable inventory. Select Manage Cable Parts to specify the available parts and their properties.
●       Define the main power supply area or areas, where dimmer, power distribution, and DMX signals originate.
●       Place distributors (plugboxes and/or breakouts) on the trusses, located near the electronic devices that require the power and/or signals.
●       Draw commonly-used cable routes with the Cable Path tool.
●       Use the Cable tool in Single Connection mode to place cables like feeder cables connecting the power supply to the power distribution racks and/or dimmer racks.
●       Use the three patching modes of the Cable tool to place and connect multi cables from power distribution rack and/or dimmer racks to the breakouts and/or plugboxes. From there, connect to the individual electronic devices that require the power or signals. Use the Daisy Chain mode for adding signal cables or power jumpers between objects like lighting devices, clicking each device to connect in order.
●       If needed, adjust the cables with the Reshape tool or the Split tool, or change the cable configuration.
●       Label the cables and distributors with the Data Tag tool.
●       Create a cable parts report listing all of the cables required for the venue.
Setting cable preferences
Managing cable parts
Placing distributors
Drawing cable paths
Inserting cables
Creating a cable report
Cable tools
