Many properties of an animation path can be established or edited only in the Object Info palette. Other edits can be made with a combination of manual manipulation of the drawing object and parameter settings; see Editing animations.
Click
to show/hide the parameters.
Parameter |
Description |
Length |
Displays the length of the path |
Path Type |
Displays the animation path type. Animation paths have different behavior depending on the type; see Types of animation path objects |
Duration |
Set the total time the animation will run. This parameter is linked to the Duration in the Create Movie dialog box; changing the value in either place changes it in both places. |
Camera Height |
For a Walk Path Type, set the camera height above the model surface; the camera remains at that height above the surface of the active design layer (which may not be the same layer the animation path object is on) as it follows the terrain/slab, including climbing stairs |
Preview |
Play |
Plays the animation in first- and/or third-person view in one or more view panes; the animation plays starting with the selected keyframe |
Pause |
When an animation is playing, pauses the movement and allows access to edit the parameters in the Object Info palette |
Skip Forward |
Click to select the last keyframe on the path |
Skip Backward |
Click to select the first keyframe on the path |
Time (0%–100%) |
Enter a number or move the slider to move the camera to a location defined as a percentage of the Duration |
Activate Camera View (appears when no camera is activated) |
Links the view in the selected view pane to the camera object on the animation path; when the camera is activated, the view pane displays the active view of the camera position on the path |
Deactivate Camera View (appears when a camera is activated) |
Unlinks the view pane view from the camera position. Any navigation actions other than editing the keyframes or the settings in the Object Info palette automatically deactivate the live camera view. The same custom 3D view displays, but the link to the animation path object is no longer active. Click Activate Camera View again with the view pane active to reestablish the link. |
Open Camera View in New Pane |
Opens a floating view pane and activates the camera view |
Keyframe |
Keyframe |
Use the Next and Previous arrow buttons to move forward and backward sequentially through the keyframes |
Add Keyframe |
When the camera base is not located on an existing keyframe, adds a keyframe to the path at the camera’s location; see Adding and deleting keyframes |
Delete Keyframe |
Deletes the selected keyframe |
Speed (-99%–100%) |
Enter a number or move the slider to set the speed of the camera near the selected keyframe relative to the other keyframes on the path; see Editing a camera’s speed |
View Angle (12°–130°) |
Enter a number or move the slider to set the camera’s view angle. This can also be done by manually manipulating the camera; see Changing the camera’s view angle. |
Display Frames |
Displays hash marks for each camera frame on the path. More camera frames around a keyframe indicate the camera moves more slowly in that area. Fewer frames indicate the camera moves more quickly along that part of the path. |
Keyframes |
Displays the number of keyframes on the path |
Animation |
Create Movie |
Opens the Create Movie dialog box to prepare a movie file to share; see Creating a movie of an animation |
Name |
Enter a name for the animation path; the name must be unique on the design layer |
Viewing an animation within Vectorworks
