Furniture and fixtures
DesignSeries.pngCreating custom cabinets
Mode
Tool
Tool set
Custom Cabinet
Furn/Fixtures
The Custom Cabinet tool provides flexibility in the design of a variety of casework, such as shelves, cupboards, and wardrobes.
The Vectorworks software also provides tools to insert base, wall, and utility cabinets and shelving units that require less customization; see Inserting cabinets and Inserting shelving units.
To create a custom cabinet:
1.      Click the tool and mode.
2.Do one of the following:
●       Click Active Def on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the Custom Cabinet Settings dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Custom cabinet settings
Custom cabinet settings: Base pane
Custom cabinet settings: Details pane
The custom cabinet preview changes to a front view and becomes interactive to specify the cabinet’s details. Click on the preview in order to activate and set the parameters on this pane; many parameters are enabled only when the preview is clicked. When you click on a column, box, or vertical divider of the preview, it becomes highlighted to indicate which section you are editing. Hold the Shift key to select multiple columns or multiple boxes within the same column; edits apply to all selected sections.
Custom cabinet settings: Attributes pane
To control appearance and visibility, attributes and textures can be applied separately to different parts of the custom cabinet (called construction groups).
3.Click to place the object, and click again to set the rotation.
Resource Selector
The Object Info palette
Editing custom cabinets
