DesignSeries00010.pngInserting shelving units
Mode
Tool
Tool set
Shelving Unit
Furn/Fixtures
The Shelving Unit tool provides access to a variety of standard configurations available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own style resources (see Concept: Plug-in object styles).
In addition to these common shelving units, Vectorworks offers the flexibility of creating custom cabinets (see Creating custom cabinets).
To insert a shelving unit:
1.      Click the tool and mode.
2.Do one of the following:
●       Click Active Def on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Click on the drawing to place the object, and click again to set the rotation.
4.Optionally, create a style resource from the object (see Creating plug-in object styles).
Resource Selector
The Object Info palette
Symbols within a wall
