Spot00040.pngPlacing lighting pipe ladders
Tool
Tool set
Lighting Pipe Ladder
Rigging
Insert and configure a lighting pipe ladder object with the Lighting Pipe Ladder tool. Lighting pipe ladders function as rigging objects, so lighting devices and other loads can attach directly to the ladder. Lighting pipe ladders support full 3D rotation, and they can be used to create schematic views.
In addition to individual objects created using the Lighting Pipe Ladder tool, it you can access a variety of standard lighting pipe resources and custom styles (see Concept: Plug-in object styles).
Mode
Description
Point Insertion
Inserts the ladder vertically with two clicks to place and set the rotation
Rectangle Insertion
Inserts the ladder horizontally by clicking two diagonal points
Width
Sets the ladder’s width, for use with Point Insertion mode
Height
Sets the ladder’s height, for use with Point Insertion mode
Preferences
Opens the object properties dialog box to set the default preferences for lighting pipe ladders
Style
Opens the Resource Selector to select a symbol for placement; double-click a resource to activate it
To insert a lighting pipe ladder:
1.      Click the tool.
2.Do one of the following:
●       Click Style on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Do one of the following:
●       To insert a vertical ladder, click Point Insertion mode and set the ladder’s Width and Height.
●       To insert a horizontal ladder, click Rectangle Insertion mode.
4.Click twice in the drawing area to draw the lighting pipe ladder according to the modes selected.
5.Optionally, create a style resource from the object (see Creating plug-in object styles).
Inserting hanging positions
Concept: Hanging positions
Concept: Rigging objects
