Spot00056.pngTruss configuration requirements
A great deal of flexibility is incorporated in the Spotlight truss object. However, in order to create a valid truss, the wide variety of configurations leads to certain restrictions in the application of truss properties.
If a truss is drawn that does not meet these requirements, an alert message is generated.
●       The width and height of the truss must be greater than three times the chord width
●       The truss hanging angle must be between -90° and +90°
●       A triangular truss must form a valid triangle
●       The chord diameter must be greater than zero
●       A pre-rigged truss cannot have lacing
●       A pre-rigged truss cannot be folding
●       Only box trusses can be pre-rigged
●       A folding truss cannot have top lacing
●       Folding is not allowed on a stacking truss
●       Top lacing is not allowed on a stacking truss
●       The top brace diameter must be less than or equal to the chord width
●       The side brace diameter must be less than or equal to the chord width
●       The connection interval must be greater than the ladder bar spacing
●       Ladder bar spacing must be greater than three times the top brace size
●       If the section is too small, lacing may not be drawn
Inserting a straight truss
Inserting a curved truss
Replacing stage decks and trusses with symbols
