DesignSeries00004.pngInserting a node with the Marionette tool
Mode
Tool
Tool set
Insert
Basic
The Marionette tool places nodes, and also enables a special Debug mode for troubleshooting.
Mode
Description
Current Node list
Opens the Resource Selector to select a node for placement; double-click a node resource to activate it
Insert
Enables the selection and placement of nodes from the Current Node list
Debug
Allows for troubleshooting and debugging networks, including the networks inside of wrapper and object nodes; see Debugging a Marionette script for more information
Preferences
Opens the Marionette Preferences dialog box.
●       Cache last run in debug mode caches data from the latest run of the network. Select this option to display the values that flowed through each wire without re-running the script. See Debugging a Marionette script.
●       Leave current node selected after run leaves the current node (the node used to run the script) selected after the script executes. Deselect this option to select the objects created by the script instead. See Running a Marionette script.
●       Content provides links to helpful resources.
Marionette nodes are page-based objects, displaying on the screen plane and scaling to the page dimensions. They should be worked with in Top/Plan view.
Nodes are color coded and categorized by function. A node reference is available online at developer.vectorworks.net/index.php/Marionette.
The nodes’ input and output ports have prefixes denoting the type of data that can pass through them.
Prefix
Data type
b
Boolean
h
Handle
i
Integer
item
Item (any object type)
list
List (any object type)
m
Matrix
n
Number/Dimension
p
Point
s
String
v
Vector
To insert a node:
1.      Click the tool and mode.
2.Click Current Node on the Tool bar to select a resource from the Resource Selector.
In the Resource Selector, a description of each node displays as the cursor hovers over the node.
3.Click in the drawing to place the node.
The node properties can be accessed from the Object Info palette.
Marionette node types
Marionette networks
Marionette Wrapper nodes
Creating menu commands from wrapper nodes
Using object nodes
Saving and exporting Marionette networks
