DesignSeries00042.pngEditing roof objects
Once a roof object has been created, there are multiple ways to edit it:
●       Edit some parameters from the Object Info palette.
●       Change roof edge shapes (such as hip or gable) using the Selection tool and the Edit Roof Settings dialog box.
●       Create cutouts in the roof using the Clip tool or Clip Surface command.
●       Reshape the roof object using the Reshape tool.
●       Add an accessory: attic, soffit, or fascia (Vectorworks Architect required).
Roof properties
Changing the roof edge shape
Reshaping roof objects
Adding roof elements to roof objects and roof faces
Creating cutouts in a roof object
Adding roof accessories
Using roof styles
Creating roof components
Roof and wall associations
