Double-Line Polygon tool
Tool
Tool set
Shortcut
Double-Line Polygon
Basic
●       Alt+8 (Windows)
●       Option+8 (Mac)
Use the Double-Line Polygon tool to create a wide variety of open or closed polygons that have two parallel lines, a double-lined polygon with a width, or two parallel lines with a polygon fill. Double-line polygons can have as many as 32,767 vertices.
Mode
Description
Top Control Line
The cursor draws the top/left line
Center Control Line
Creates lines equidistant from the cursor
Bottom Control Line
The cursor draws the bottom/right line
Custom Control Line
Specify an offset value
Preferences
Opens the Double Line Preferences dialog box for specification of additional object parameters
Separation
The distance between the double lines; the value must be greater than zero
To create a double-line polygon:
1.      Click the tool and mode.
2.Enter the distance between the double lines in the Separation field on the Tool bar.
3.Click Preferences to open the Double Line Preferences dialog box and specify the tool’s default parameters.
4.Click to set the polygon’s start point (first vertex).
5.Click at each vertex.
6.Double-click to mark the polygon’s end point (final vertex).
Alternatively, if Create Polygons or Creates Lines and Polygons is selected in the Double Line Preferences dialog box, after completing all but the final click, press the keyboard shortcut to automatically close the polyline. The shortcut also closes path-based objects, such as hardscapes and spaces, that function similarly to the Polyline tool. See Modifying special shortcuts to change the shortcut.
2D Polygon tool
Creating double lines
Applying components between double lines
Regular (equal-sided) polygon
Displaying and reversing object direction
