Regular (equal-sided) polygon
Use the Regular Polygon tool to create single-line closed polygons in which all sides of the polygon are the same length. The Push/Pull mode is available in 3D views for instantly extruding the polygon after creation.
Mode
Description
Inscribed
Creates a polygon by drawing its radius to a corner
Circumscribed
Creates a polygon by drawing a radius to the mid-point of a side
Edge
Creates a polygon by drawing one of its sides
Push/Pull
(3D views only)
Instantly extrudes the polygon after creation; see Push/Pull mode of planar tools
Push/Pull Combine
(available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged
Number of Sides
Sets how many sides the polygon has (from 3 to 4000)
Press and hold the Option (Mac) or Ctrl (Windows) key while drawing to toggle between circumscribed and inscribed modes.
Regular polygon by inscription
Mode
Tool
Tool set
Shortcut
Inscribed
Regular Polygon
Basic
●       Alt+Shift+R (Windows)
●       Option+Shift+R (Mac)
To create a regular polygon by inscription:
1.      Click the tool and mode.
2.Enter the Number of Sides for the polygon (a number from 3 to 4000).
3.Click to set the center of the polygon.
4.Click to set the corner radius.
Regular polygon by circumscription
Mode
Tool
Tool set
Shortcut
Circumscribed
Regular Polygon
Basic
To create a regular polygon by circumscription:
4.Click to set the edge radius.
Regular polygon by edge
Mode
Tool
Tool set
Shortcut
Edge
Regular Polygon
Basic
To create a regular polygon by edge:
3.Click to set a corner of the polygon.
4.Click to set an adjacent corner of the polygon and define an edge.
2D Polygon tool
Double-Line Polygon tool
Displaying and reversing object direction
