Arch00032.pngInserting ramps
Tool
Tool set
Ramp
Building Shell
To insert a ramp:
1.      Click the tool.
2.Do one of the following:
●       Click Active Def on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Click on the drawing to place the object, and click again to set the rotation.
4.Optionally, create a style resource from the object (see Creating plug-in object styles).
Workflow: Creating curved ramps
Inserting a stage ramp
