Command |
Path |
Batch Rename |
Tools |
Industry naming standards, or the need to better organize a drawing structure, can require you to rename classes, layers, viewports, saved views, and resources in a file. The Batch Rename command allows you to make certain changes to the names of multiple drawing elements in the file at once, such as adding a prefix to a list of class names.
Only items in the current file can be renamed; referenced items are not eligible for this operation.
To batch rename drawing elements:
1. Select the command.
The Batch Rename dialog box opens.
Click
to show/hide the parameters.
2.Select the Category of items to be renamed and the Operation, and enter the changes into the operational controls.
The dynamic Preview displays the New Name in green if there is no conflict with completing the operation, or in red if there is a naming conflict.
3.In Preview, all listed items are selected for the operation by default. Click in the first column to remove the check mark and deselect any items that should not be renamed.
4.Click Apply Changes. You can then complete additional operations without exiting the dialog box.
Clicking Cancel to exit the dialog box undoes all operations that have been applied in that session.
