DMX transforms
Use DMX transforms to scale, rotate, and move selected items in the scene. Scaling and movement are independent from the object’s rotation. Scaling does not apply to lighting devices.
To transform multiple selections at once, you can group them in a layer; see Organizing the scene contents. When a layer is transformed, all items contained in that layer are transformed accordingly. A transformed lighting device's pan and tilt are relative to the transformed position.
To significantly improve performance for DMX transforms, disable shadows from the Basic: Graphics tab or Advanced: Graphics tab. If shadows are needed, set Dynamic Shadows to None from the Advanced: Graphics tab; shadows will be disabled only for transformed objects.
To scale objects by DMX input:
Select one or more objects.
Alternatively, select a layer in the Scene Graph palette that contains all of the objects to transform. Lighting devices cannot be scaled.
In the Properties palette, select DMX for the XForm Mode.
Expand the DMX XForm heading to access the parameters.
Set the XForm Universe to specify the universe.
Set the XForm Channel to specify the DMX address.
Enter the XForm Scale values to specify the scale factors. Scaling is not affected by the object’s rotation.
Scale X sets the object’s X-axis scale.
Scale Y sets the object’s Y-axis scale.
Scale Z sets the object’s Z-axis scale.
Set the DMX profile for scaling.
Channel |
Coarse/Fine |
Purpose |
%: Function |
10 |
Coarse |
XForm Scale X |
0–100 |
11 |
Fine |
12 |
Coarse |
XForm Scale Y |
0–100 |
13 |
Fine |
14 |
Coarse |
XForm Scale Z |
0–100 |
15 |
Fine |
To rotate items by DMX input:
Select one or more lighting devices or objects.
Alternatively, select a layer in the Scene Graph palette that contains all of the items to transform.
Select the Rotation Axis, or select None.
Enter the Rotation Delta to set the maximum angle of index rotation.
Enter the Rotation Rpm to set the maximum speed of continuous rotation.
Set the DMX profile for the rotation.
Rotation occurs around the local origin, not the world origin.
Channel |
Coarse/Fine |
Purpose |
%: Function |
7 |
Coarse |
XForm Rotation (Index) |
0–100: Rotation |
8 |
Fine |
7
Coarse |
XForm Rotation (Continuous) |
0–0: No rotation 48–1: Clockwise rotation 49–51: No rotation 52–99: Counter-clockwise rotation 100–100: No rotation |
8 |
Fine |
9 |
XForm Rotation Control |
0–20: Index rotation 21–40: Continuous rotation 41–100: Reserved |
There are three “dead zones” where no rotation occurs in the Continuous Rotation channel: 0%, 49–51%, and 100%. The rotation is clockwise at 48–1% (where the effect increases as DMX value decreases) and counter-clockwise at 52–99%.
To move items by DMX input:
Enter the XForm Delta values (in inches) to specify the direction and magnitude of movement. The movement is not affected by the item’s rotation. The direction is relative to the item’s local coordinate space.
Delta X controls the range of lateral movement.
Delta Y controls the range of upward/downward movement.
Delta Z controls the range of forward/backward movement.
The Position X/Y/Z values in the Properties palette determine the selected items’ starting position.
Set the DMX profile for the desired movement.
50% indicates the center of the range of movement.
Channel |
Coarse/Fine |
Purpose |
%: Function |
1 |
Coarse |
XForm Delta X |
0–100: X axis movement |
2 |
Fine |
3 |
Coarse |
XForm Delta Y |
0–100: Y axis movement |
4 |
Fine |
5 |
Coarse |
XForm Delta Z |
0–100: Z axis movement |
6 |
Fine |
