Adding drop points
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Drop Point
Cable Route |
A drop point represents the location where cables are delivered, like a wall box, floor pocket, socket on the wall, or cables coming out of the wall.
A 3D equipment rack is considered to be a drop point.
Drop points cannot be connected to equipment items that are placed in 2D racks.
To add a drop point to the drawing:
Click the tool and mode.
Click Drop Point Style on the Tool bar to select a resource from the Resource Selector.
Click to place the object, and click again to set the rotation. Drop points can be inserted in a wall, floor, slab, etc. or they can be stand-alone.
2D and 3D views of a wall pocket drop point
The parameters can be edited later from the Object Info palette. Optionally, create a style resource from the object (see Creating plug-in object styles). Once added to the drawing, connect the drop point to the cable path network and connect equipment to the drop point. Drop points can also be connected to a slab object.
You can connect multiple equipment items to a drop point by selecting all of the equipment control points with the Unrestricted Interactive Scaling mode of the Selection tool enabled. Drag the control points towards the drop point.
Parameter |
Description |
Style |
Replace, remove, or edit the current style, or create a new plug-in object style for this object. Editing a style changes all instances in the file that use the style. |
Hide style parameters |
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette |
General |
Name |
Enter a name for reporting and paperwork |
Category |
Select a category for the type of drop point symbols available from the Symbol resource selector |
Connected |
Indicates the number of connected equipment items |
Symbol |
Displays the currently selected symbol; select a different symbol if needed |
Location |
Indicates the location of the layout room, if the drop point was placed in one |
