Placing equipment
Tool |
Tool set |
Equipment Item
Layout |
Equipment items can be placed stand-alone or within a rack, and they can be used to identify objects as equipment. Equipment items are typically associated with devices on the schematic layer.
To identify non-rack equipment with a room location, draw a polygonal layout room on the architectural layer with the Layout Room tool.
Rack equipment: If placed in a rack, equipment becomes associated with the rack, inheriting its ID/location and moving with the rack. Modular equipment can optionally be placed within a rack frame located in the rack. To connect rack-mounted equipment to a cable path network, connect the rack.
Equipment items that are placed in 2D racks cannot be connected to drop points.
Stand-alone equipment: Place equipment items in the model and connect them to the cable network; see Creating cable networks.
Associated equipment items and objects: You can associate equipment items with Vectorworks Spotlight objects such as cameras, speakers, lighting devices, and video screens. Valid objects are available for placement from the Event Design tool set.
Associated devices and equipment items: If the name of the equipment matches that of an existing device, the equipment automatically uses the device’s make and model number. Once the device and the equipment item are associated, the equipment parameters define the device's make and model, as well as its physical and location data.
If the drawing already contains devices, the Create Equipment command automatically creates an equipment item for each device; see Creating equipment items automatically.
To place equipment:
Click the tool.
Click to place the equipment in the drawing, within an equipment rack, or over a valid object. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter |
Description |
General |
Name |
Enter the equipment name for labels and reports; if the name is the same as an existing device on the Schematic layer, the device’s make and model information is automatically linked and entered. If attaching the equipment item to an object, name it after the corresponding device. Connect CAD can then recognize the corresponding device on the schematic. Name the equipment item with a CTP_ prefix to create a connector panel. If needed, select Text > Size to change the size of the Name text only. |
Manufacturer |
Make/Model |
Enter the manufacturer’s make and model information |
Physical |
Height/Width/Depth |
Enter the dimensions of the equipment |
Power |
Enter the power requirements of the equipment |
Weight |
Enter the equipment’s weight |
Height RU |
Select the height of the equipment in rack units |
Rack Width |
Select whether the width of the item is constrained by the half or the full width of the equipment rack. Select non-rack to use any width, unconstrained by the rack or not placed within a rack. A control point on the item allows you to manually adjust the height and width by dragging. If the Rack Width is constrained, only the height can be adjusted by the control point.
Mounting |
Select whether the equipment mounts to the front or rear of the equipment rack |
Mounting Depth |
Offsets the equipment from the rack by the specified distance |
Configuration |
Modular |
Indicates the equipment is modular, taking up several slots in the equipment rack |
Number of slots |
Enter the number of slots occupied by a modular configuration |
Display |
Show Text |
Toggles text display on the equipment item in both 2D and 3D |
Text align |
Select the text alignment for the Name label |
Draw in Front View |
When the equipment is not placed in a rack, and is not part of a custom panel, draws the equipment in Front view |
Use Symbol |
Select the option, and then click to select an equipment item resource from the Resource Selector |
Location |
Displays the containing layout room and equipment rack ID, as well as the rack location (in rack units) and slot if placed in a rack frame. If only the rack ID is specified, the equipment is placed below the rack. If the equipment item is associated with a device on the Schematic layer, the location information updates automatically for the device. |
Custom Panel |
Name the equipment item with a CTP_ prefix to enable these additional connector panel parameters. See Creating connector panel layouts. |
Get Connectors |
Places detailed views of associated connectors on the custom connector panel equipment |
Create Panel Devices |
Places corresponding Conn panel devices on the Rack Elevation layer |
An equipment item object includes a control point, which is visible in 3D views. If you are creating a cable network, drag the control point to a drop point object to connect it; valid drop points are highlighted. Drag the control point off of the drop point to disconnect it (or select Detach from Drop Point from the object drop-down context menu).
You can connect multiple equipment items to a drop point by selecting all of the equipment control points with the Unrestricted Interactive Scaling mode of the Selection tool enabled. Drag the control points towards the drop point.
An equipment item can also be associated with a drawing object from the Event Design tool set. When placing the equipment item, place it on the valid object. Valid objects are highlighted at placement; after placement, the equipment item is identified as an icon (in Top/Plan view) or a locus (in 3D views) over the object.
Alternatively, after placement, drag the equipment item's control point to the object to attach it. Once the equipment item and the object are associated, they move together. Next, attach the equipment item to a cable path network or to a drop point. You can also use the Cable tool from the Cable Route tool set to make this connection.
Attaching an equipment item to a camera, and attaching the equipment item to a drop point
Detach the equipment item from the object or drop point using the drop-down context menu. Select the Detach From [object] or Detach from Drop Point command.
Viewing front and rear mounted equipment
Command |
Path |
Front-Rear Rack View |
ConnectCAD > Layout |
Some equipment is mounted to the front, and some to the rear, of the equipment rack, based on the Mounting selection in the Object Info palette of a selected device. For times when you need to see only equipment mounted in front or rear configuration, this command creates classes to control the visibility of the equipment.
To adjust the equipment view for all equipment racks:
Select the command.
The Change rack view dialog box opens.
Select the equipment to view based on its mounting location.
Front: Only front mounted equipment is visible
Both (Rear grayed): Front mounted equipment appears normally; rear mounted equipment is gray
Both: Front and rear mounted equipment appears normally
Both (Front grayed): Rear mounted equipment appears normally; front mounted equipment is gray
Rear: Only rear mounted equipment is visible
To view all of the equipment again after hiding or graying some of the items, select Both.
In a viewport, accomplish the same effect by using viewport class overrides to control the visibility of the Sys-Equip-Front and Sys-Equip-Rear classes in the viewport.
