Standard plug-in object styles without catalog options
Command
Path
Create Plug-In Style
Tools
Context menu
To create a plug-in object style:
Select an unstyled instance of the plug-in object in the drawing area.
Select the command, or right-click on the unstyled plug-in object and select New Plug-in Style from Unstyled Plug-in from the context menu.
The Select Folder dialog box opens.
Select the destination folder for the plug-in object style.
The Plug-in Object Style dialog box opens, populated with the parameter values of the selected instance.
Enter the Style Name, which must be unique in the file.
Click Plug-in Style/Instance Settings.
The Plug-in Style/Instance Settings dialog box opens, with the Style Name displayed.
For each parameter, click the By Style/Instance button and toggle to the desired setting.
Click OK to return to the Plug-in Object Style dialog box.
Specify the parameter values. For style parameters, this value is fixed for every object that uses this plug-in object style and cannot be edited from the object’s settings, preferences, or properties dialog box. Instance parameter values set here are the default values for newly placed instances; they can be edited for each instance from the object’s settings, preferences, or properties dialog box, and from the Object Info palette.
For the object properties dialog box accessed from the Preferences button on the Tool bar, changing the values of instance parameters sets a new default for subsequently inserted objects, but does not change the plug-in style’s default settings.
In addition to object-specific parameter settings, you can control some plug-in object style settings regardless of the object type, such as whether the plug-in object is a window or title block border.
To set visibility-related options including the plug-in style’s class and the 2D component and cut plane display, see Additional plug-in object style and instance options.
For plug-in object styles that use 2D components, you can define the components as part of the style; see Creating 2D components for symbol definitions and plug-in objects.
Creating plug-in object styles
Custom plug-in object styles without catalog options
Custom plug-in object styles with catalog options
Standard plug-in object styles with catalog options
