Applying a texture with Apply to Object mode
Mode
Tool
Tool set
Apply to Object
Texture
Basic
Apply to Object mode applies textures to supported objects (see Supported objects for the Texture tool). To apply textures to supported objects within a symbol definition, right-click the object and select the component to edit in object editing mode (see Object editing mode).
To apply a texture to a supported object:
Click the tool and mode.
Click Texture from the Tool bar to select a resource from the Resource Selector.
Alternatively, press the Alt key (Windows) or Option key (Mac) to temporarily invoke Pick Up mode and click an object or face in the drawing to activate the texture.
Move the cursor over the object, which is highlighted; click to apply the texture.
The texture is applied to the object, and if the object is selected, the Render tab of the Object Info palette shows the texture applied overall.
If a texture is already applied to a face when the Apply to Object mode is used to apply an overall texture, the face retains its original texture as an override; the overall texture is applied only to the untextured faces.
Applying textures to objects and faces using the Texture tool
Applying a texture with Apply to Face mode
Applying a texture with Replace Matching Texture mode
Managing object textures from the Object Info palette
Textures on 3D objects
