 Truss properties
Truss properties
  Many of the truss parameters can be edited from the Object Info palette; other truss parameters must be edited from the Truss Properties dialog box; see Setting custom truss parameters.
| Parameter | Description |
| Orientation parameters | To orient the truss, Vectorworks applies the Roll, Hanging Angle, and Rotation settings in the this order |
| Roll | Rotates the truss object on its X axis; the truss rotates around its insertion point |
| Hanging Angle | Rotates the truss object on its Y axis; the truss rotates around its insertion point |
| Rotation | Rotates the truss object on its Z axis; the truss rotates around its insertion point |
| Properties |
| Symbol | Displays the truss symbol |
| Type | Displays the truss type, manufacturer, or catalog identification number |
| Name | Identifies the truss section; if the truss is converted to a hanging position, the name of the hanging position displays automatically |
| ID | Unique identifier for truss calculations and labels; if blank, a value is automatically assigned when calculations are run (Braceworks required) |
| Position Name | Enter a name for identification and reporting purposes. When the truss is used as a hanging position, this name automatically populates the Position field of any attached load objects. |
| Height/Width | Displays the height and width values of the truss |
| Total Weight | Sets the total gross weight of the truss; corner trusses are considered as point loads in calculations, while all other truss types are considered as distributed loads |
| Distributed Weight | Displays the weight per unit of length for the truss |
| Length (straight or curved truss only) | Displays the length of the truss |
| Hinge Angle (hinge truss only) | Sets the angle between the hinge parts. You can manually adjust the hinge angle by moving the control points on the hinge truss.
| Insert Locking Pipe (book hinge only) | Inserts a lighting pipe to connect and lock the hinge parts. The lighting pipe is considered as a separate object in Braceworks calculations.
| Cross Section | Displays the cross section unique ID number, when a cross section file has been associated with the truss as described in Specifying cross section data Cross section information is required for valid calculations; if there is no identified cross section, calculations will not be complete. |
| Connectable with | Displays the ID of rigging objects that can be connected to this truss in Auto Connect mode, forming a structural system |
| Truss System | Displays the name of the truss system to which the truss belongs, along with the truss line number |
| Display |
| Draw 3D Only | Hides the 2D-only portion of the object, making it easier to view and rotate in 3D views |
| Center line | In Top/Plan view, displays the truss center line; some load objects are attached at the truss center line |
| Actions | See Modifying trusses and systems for parameter descriptions |
