Slab drainage settings
Slab drainage settings for the selected slab are set before the drainage elements are added, in the Slab Drainage Settings dialog box; access it by clicking the Slab Drainage tool from the Building Shell tool set and then clicking Settings from the Tool bar. These settings serve as the new defaults for drainage elements added to the slab until the settings are changed.
Some, but not all, of the settings for individual drainage elements can be edited after placement with the Edit mode of the Slab Drainage tool (see Editing slab drainage elements).
Parameter |
Description |
Default Slope |
Set the default slope for new slope valleys |
Minimum Slope |
Indicate the minimum slope; any slopes below this value are drawn differently to provide a visual indication |
Drain Diameter |
Set the default diameter for new drains |
Drain Height |
Set the default elevation relative to the top of the component for new drains |
Maximum Height |
Set the maximum height for any point on the curb |
Elevation Offset |
Set the elevation offset for new drains |
Default drain symbol |
Places a drain symbol at new drain locations; select the symbol |
Drain Notes |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the drain notes in the same class as the slab object. |
Elevations |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the elevation labels in the same class as the slab object. |
Slope Arrows |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the slope arrows in the same class as the slab object. |
Slope Values |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the slope values labels in the same class as the slab object. |
Display Precision |
Select up to ten digits of decimal precision for the slope values labels |
Line Length |
Enter the line length in world units of the lines for the slope arrows |
