Specifying ConnectCAD settings
Command |
Path |
ConnectCAD Settings |
ConnectCAD |
Prior to beginning the schematic design, set up the default ConnectCAD settings. The settings apply to the current file.
To specify the ConnectCAD settings:
Select the command.
The ConnectCAD Settings dialog box opens.
Click the General Settings pane to set global default parameters.
Parameter |
Description |
Device Units |
Power |
Specify watts or kilowatts for device power requirements |
Weight |
Select the units for weight measurements (use kilograms for best results) |
Circuit Label Offset |
Circuit Number Offset (Grid Spaces) |
Sets the position, in grid spaces, of the circuit number label |
Connector Type Offset (Grid Spaces) |
Sets the position, in grid spaces, of the connector type label |
Data Source |
Enable Device Builder database |
Allows the Device Builder tool access to the database of existing makes and models. If you are creating custom devices with the device builder, you may want to disable this option so that you do not need to scroll through the existing device makes and models. New devices that you create are saved as symbol definitions. |
Use custom data only for signals, connectors, cable types, and devices |
Disables the Device Builder database and accesses custom device data in user and workgroup folders |
HopOver |
Enable automatic hopover |
Automatically creates hop overs where two circuits intersect. Enabling this option disables the HopOver tool. For information about using this tool to create hop overs manually, see Creating a circuit hop over. |
Edit Default Circuit Graphics |
Allows you to customize the default appearance of circuit arrows and/or bubbles; see Customizing ConnectCAD objects |
Click the Panel Settings pane to set up the jackfield and terminal panel parameter defaults. These settings override any existing custom labels.
Parameter |
Description |
Panel Type |
Select each type of jackfield or terminal panel to set its label parameters |
Group Series |
Sets the sequence of the letters and numbers available from the Group list in the Tool bar |
Panel Series |
Sets the sequence of letters and numbers available from the Panel list in the Tool bar. The label type determines how these are used. For example, for jackfields labeled AB, CD, EF..., each character pair is taken from this list. For an A, B, C... label style, these are taken one by one. |
Jackfield Label Type |
Select a labeling style for jackfield and linked jackfield labels. The style can either be the panel and port number, separated by the Delimiter Char, or an alphabetical identifier. |
Terminal Panel Label Type |
Select a labeling style for terminal panel labels |
Delimiter Character |
Specifies the delimiter character for jackfield and terminal panel numeric styles |
Second Delimiter Character |
Specifies the second delimiter character for terminal panel numeric styles |
Sets the maximum number of holes available for each panel type (video, audio, data, and optical; also DIN Rail terminal panel). Select Other to specify a custom number of holes in the Enter New Panel Size dialog box. |
Click the Numbering pane. Select a standard numbering system to use, or add a custom system. See Cable numbering rules for more information about numbering rules.
Parameter |
Description |
Cable Numbering Systems |
Specifies the numbering system to use for drawing circuits, when circuits are created or renumbered. Several standard systems are included by default. Click in the Use column to use that numbering system (a check mark indicates the currently selected system). |
Opens the Edit Numbering System dialog box, to create a custom numbering system. The currently selected system displays for reference; enter a new System Name and System Description, and then add or edit rules to create a custom system. |
Opens the Edit Numbering System dialog box, to edit the currently selected numbering system. Click Add to open the Edit Numbering Rule dialog box; edits made here create a new rule that is appended to the end of the rules list. Click Edit to open the Edit Numbering Rule dialog box, where you can change the Match Rule parameters/prefix and the Cable Number format. Click Edit as text to open the Edit Numbering Rule dialog box, which displays the currently selected rule as a formula for editing directly. Click Delete to delete the currently selected rule. Click and drag in the # column to reorder the rules. |
Delete |
Deletes the currently selected numbering system |
Click the Signals pane. The list of available signals for the Device Builder and Socket tools displays according to priority (uncategorized, custom, workgroup, and default) and can be customized. Default items cannot be deleted, but you can change their class settings. You can create a duplicate entry in the list and customize it as required; the custom duplicate is used instead.
Click to show/hide the parametersClick to show/hide the parameters.
Parameter |
Description |
Signal Types list |
Lists the available signals, with prefix, connector, description, and attribute settings. Custom types: All information except the line type attribute can be edited inline. Uncategorized, workgroup, and default types: The prefix, connector, and attributes (except line type) can be edited inline. When signal data (not attributes) are edited, the row displays in bold, and the Delete button changes to Reset. |
Add |
Adds a new signal to the list; the new signal is saved in the user folder. Edit the line for the new entry; enter the signal name, select a prefix and connector from each list, enter the description, and then click Edit Class to set the attributes. |
Edit Class |
Opens the Edit Class(es) dialog box, to edit the attributes of the class assigned to the currently selected entry. See Setting class properties. Double-clicking signal attributes in a row also opens the Edit Class(es) dialog box. |
Edit Preferences |
Opens the Connector and Cable Preferences dialog box, to edit the connectors and cable types displayed for the selected signal. Double-clicking signal data in a row also opens the Connector and Cable Preferences dialog box. Items can be sorted by column. Click in the Use column to include or to exclude the connector and the cable type. Including the connector and cable types for the signal displays those items with the preferred types near the top of the list of available connectors and cables for that signal type. List items display according to priority: uncategorized, preferred, custom, workgroup, and default. |
Delete |
Removes the selected custom entry from the list; changes to Reset when signal data are edited |
Reset |
Restores default settings; displays only when signal data are edited |
Click the Connectors pane. The list of available connectors displays according to priority (uncategorized, custom, workgroup, and default) and can be customized. Default items cannot be edited or deleted; however, you can create a duplicate entry in the list and customize it as required, and the custom duplicate is used instead.
Parameter |
Description |
Connector Types list |
Lists the available connectors and description. Custom types can be edited inline. |
Add |
Adds a new connector to the list; the new connector is saved in the user folder. Edit the line for the new entry; enter the connector name and description. |
Delete |
Removes the selected custom entry from the list |
Click the Cable Types pane. The list of available cable types displays according to priority (uncategorized, custom, workgroup, and default) and can be customized. Default items cannot be edited or deleted; however, you can create a duplicate entry in the list and customize it as required, and the custom duplicate is used instead.
Parameter |
Description |
Cable Types list |
List the available cable types, with description and cable outside diameter size. Custom types can be edited inline. |
Add |
Adds a new cable type to the list; the new type is saved in the user folder. Edit the line for the new entry; enter the cable type name, description, and diameter. |
Delete |
Click the Cables pane. You can create a list of custom cables for use by the Connect tool; select the Cable from the Object Info palette of a selected circuit. The cable name displays in the drawing, which is useful for identifying cables in a complex drawing. The list of cables displays according to priority (uncategorized, custom, workgroup, and default).
Parameter |
Description |
Cables list |
Lists the available cables and description. Custom types can be edited inline. |
Add |
Adds a new cable to the list; the new cable is saved in the user folder. Edit the line for the new entry; enter the cable name and description. |
Delete |
