Specifying update settings
Setting update frequency
Command |
Path |
Update Settings |
Tools > Database |
Database or Vectorworks file updates can be executed automatically or manually. The update settings control the frequency of automatic updates, or only permit manual updates.
If there are problems connecting to the database, an error message provides troubleshooting information. Click Details to open a log file in the default text editor application. The log file provides further information to help diagnose connection errors.
To specify update settings:
Select the command. The Update Database Settings dialog box opens. Specify the update parameters.
Parameter |
Description |
Update database |
Sets the frequency of updates from the Vectorworks file to the database |
Manually |
The database is only updated by selecting the Update External Database command |
Every record change |
Updates the database each time a record field value changes in Record Info |
Every __ minutes |
Updates the database after a set number of minutes |
Update Vectorworks document |
Sets the frequency of updates of the Vectorworks file from the database |
Manually |
The Vectorworks file is only updated by selecting the Update Vectorworks Document command |
Every __ minutes |
Updates the file after a set number of minutes |
Manually updating the database
Command |
Path |
Update External Database |
Tools > Database |
If the record fields have been changed for objects with linked fields to a database table, and the link type for the field is set to Read/Write or Write Only, the drawing data can update the database table data.
To update the database:
Select the command.
Manually updating the Vectorworks file
Command |
Path |
Update Vectorworks Document |
Tools > Database |
If database information has changed, and the link type for connected record fields is Read/Write or Read Only, the information can be automatically sent to the Vectorworks file, updating the record fields of all object instances connected to the database.
To update the record fields of all object instances connected to the database:
Select the command.
