Object database connection
The final step in setting up a database connection is to connect object instances to the database. The procedure for connecting a single object follows. If you are connecting multiple objects, see Multiple object connection.
Once connected, the connection can be edited. The connection can also be removed.
Single object connection
Command |
Path |
Object Connection |
Tools > Database |
To connect a database to an object:
Select an object.
On the Data tab of the Object Info palette, click the box for the selected format to attach the record format to the object instance. (See Attaching record formats to symbols, objects, and materials.)
The Record Fields display with default values from the record format.
Select the command. Alternatively, click Object Database Connection from the Data tab of the Object Info palette.
The Object Database Connection dialog box opens. If a row was previously selected for the object, it appears highlighted and bolded.
Parameter |
Description |
Available Records |
Lists the record formats available for the selected object (including IFC and COBie records) |
Database Connection |
Opens the Record Formats Database Connection dialog box, to connect a record format to a database table |
Add New Database Table Row |
Inserts a new row in the database table, and associates it with the object |
Use Selected Database Table Row |
Allows the database table row from the linked database table list to be selected, associating an existing row with the object |
Database Table Rows |
Selects a table row to associate with the object; this row provides data for the selected object or receives data from the selected object |
Click Use Selected Database Table Row, and then select the appropriate row for the selected object.
The record fields are populated from the database table for the record instance attached to the object.
