Bolts and nuts
Mode |
Tool |
Tool set |
Modes for Creating single lines |
Bolt and Nut (mm or inch)
Detailing |
To insert a bolt and nut (mm or inch):
Click the tool and mode.
Parameter |
Description |
Bolt Type (inch only) |
Select the bolt type
Nut Type (inch only) |
Select the nut type
Washer Type |
Select a washer type
Bolt Size |
Select the bolt size |
Bearing Length |
Specify the bearing length or click and drag the bottom bearing length control point to define the bearing length graphically
Bolt Length |
For a custom length value, deselect Use Standard Lengths and enter the length under the bearing length; alternatively, click and drag the bolt length control point to define the length graphically
Thread Style |
Select the bolt thread style
Top Washer/Top Lock Washer/Bottom Washer/Bottom Lock Washer |
Draws the bolt with top and/or bottom washers and top and/or bottom lock washers |
Nut |
Draws the bolt with a nut |
View |
Select the 2D view
Use Standard Lengths |
Automatically adjusts the bolt length to the nearest increment based on size; deselect to enter a custom length |
Adjust Bolt Length |
Automatically adjusts the bolt length based on the bearing length |
Show Center Line |
Draws the 2D bolt and nut with center line(s) |
