Hex cap nuts
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Hex Cap Nut
Fasteners |
Multiple acorn nut and hex cap nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a hex cap nut:
Click the tool and mode.
Parameter |
Description |
Size |
Select the hex cap nut size |
View (2D only) |
Select the 2D view
Show Center Line (2D only) |
Draws the hex cap nut with center line(s) |
Show Center Hole (3D only) |
Draws the hex cap nut with a center hole
