Nuts
Acorn nuts
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Acorn Nut
Fasteners |
Multiple acorn nut and hex cap nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert an acorn nut:
Click the tool and mode.
Parameter |
Description |
Size |
Select the acorn nut size |
Style |
Specify the acorn nut style
View (2D only) |
Select the 2D view
Show Center Line (2D only) |
Draws the acorn nut with center line(s) |
Show Hole (3D only) |
Draws the acorn nut with a center hole
