Screws
Lag screws
Mode
Tool
Tool set
Lag Screw
Detailing
The Lag Screw tool and Lag Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a lag screw:
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Series
Select inch or metric to display the appropriate nominal sizes
Head Type
Select the lag screw head type
Nominal Size
Select an inch or metric nominal size
Length
Enter the length under the screw head
Show Threads
Draws the lag screw with threads
Show Center Line
(2D only)
Draws the 2D lag screw with center line(s)
Inserting fastener objects using the Fastener tool
Sheet metal screws
Thumb screws
Wood screws
