Sheet metal screws
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Sheet Metal Screw |
Detailing |
The Sheet Metal Screw tool and Sheet Metal Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a sheet metal screw (self-tapping screw):
Click the tool and mode.
Parameter |
Description |
View (2D only) |
Select the 2D view
Series |
Select inch or metric to display the appropriate nominal sizes |
Head Type |
Select the sheet metal screw head type
Slot Type |
Specify the slot type
Point Type |
Select the sheet metal screw point type
Nominal Size |
Select an inch or metric nominal size |
Length |
Enter the length under the screw head (or overall length for flat head screws) |
Show Threads |
Draws the sheet metal screw with threads |
Show Center Line (2D only) |
Draws the sheet metal screw with center line(s) |
