Creating a lectern
           Command  |
           Path  |
           Create Lectern  |
           Event Design  |
After the stage and stairs have been added, a lectern can be quickly configured and placed. When placed on the stage, the lectern elevation is automatically adjusted to the top of the stage.
To add a lectern:
Select the command.
The Create Lectern dialog box opens.
             Parameter  |
             Description  |
             Choose Lectern  |
             Select one of the lecterns from the list; these are configured with default attributes and can be inserted as is. Alternatively, select a lectern shape to use as the basis for a new lectern symbol with customized attributes.  |
             Custom Attributes  |
             Customizes the selected lectern’s default attributes, creating a new hybrid lectern symbol  |
             New Symbol Name  |
             Provide a name for the new lectern symbol; the new symbol is added to the file’s resources  |
             Class  |
             To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the lectern in the None class to set the remaining attributes from the dialog box.  |
             Fill Color  |
             Set the fill color for the lectern  |
             Pen Color  |
             Set the pen color for the lectern  |
             Texture  |
             Opens the Resource Selector; double-click a resource to select it  |
Click once in the drawing to set the lectern position. Click again to set the lectern rotation.
