LandmarkPlacing point of connection objects
Tool
Tool set
Point of Connection
Irrigation
The Point of Connection tool places a Point of Connection (POC) object, which represents the source of water for the irrigation system. Normally, there is only one POC for the system. There are two types of POC: service line and custom. A service line has a known and predictable static pressure value. Custom types of POC include pumps and cisterns or other types of water sources.
To place a POC on the drawing:
Click the tool.
Click Point of Connection on the Tool bar to select a resource from the Resource Selector. Select from one of the point of connection libraries, or select a custom resource from Custom POCs.vwx and set its properties after placement.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
Parameter
Description
POC Name
Names the object, which is useful for labels, irrigation schedules, and other worksheets. Since a POC is designated for use with the Design Zone tool, it is useful to provide a name for the POC object, especially when there is more than one POC for the site.
Note
Adds a note about the object, which is useful for labels, irrigation schedules, and other worksheets, and also for making notes when saving red symbol definitions
Graphics
Symbol Name
Displays the name of the symbol used to represent the POC; <default symbol> indicates that the default POC symbol is used
Replace Symbol
Selects a different POC symbol; choose the symbol from the appropriate category
Symbol Scale
Scales the symbol with respect to the layer scale by the specified scale factor; a factor of less than one decreases the size of the symbol, while a factor of more than one increases its size
Show Pressure
Places a pressure label on the drawing
Show Flow
Places a flow rate label on the drawing
Click once to place the POC. If placing the POC over an existing pipe or irrigation pipe network, the connecting pipe is highlighted and the POC is automatically connected to the network.
Adjust the location of the POC labels by dragging the label control point.
The parameters can be edited from the Object Info palette. Available parameters depend on the POC type.
Parameter
Description
Save Point of Connection
Saves the selected POC as a red symbol definition in the active file; this would typically be done for a POC with modified data
POC Name
Specifies the POC name, which is useful for labels, irrigation schedules, and other worksheets. Since a POC is designated for use with the Design Zone tool, it is useful to provide a name for the POC object, especially when there is more than one POC for the site.
Note
Water Source Type
Indicates whether the POC originates from a service line or from a custom water source
Display in Drawing
Select either Design Information or Calculated Information to affect the display of all calculated values and coverage zones in the drawing; see Concept: Design and calculation parameters for irrigation
Design Information
The POC must be connected to display information
Required Pressure
Specifies the pressure required to operate the zone with the greatest designed pressure requirements
Pressure Differential
Specifies the additional pressure in the designed system once the required pressure has been considered
Pressure differential = output pressure - required pressure
Greatest Zone Flow
Indicates the flow rate needed to operate the zone with the greatest designed pressure requirements
Flow Differential
Reports the additional available flow rate in the designed system once the required flow has been considered
Flow differential = max safe flow - greatest zone flow
Output Pressure
Displays the amount of pressure produced by the POC, depending on the data, and therefore, the water source type
Greatest Zone Flow
Indicates the flow rate needed to operate the zone with the greatest pressure requirements
Flow Differential
Reports the additional available flow rate in the system once the required flow has been considered
Data
Output Pressure
(custom water source)
Enter the amount of pressure produced by the POC at all times
Max Safe Flow
Specify the maximum flow rate safely provided by the POC
Source Static Pressure
(service line water source)
Enter the pressure in the pipes arriving from the water service provider
Service Line Type
Select the type of service line that runs from the water supply pipe to the irrigation system
Service Line Size
Select the service line size that can safely be provided by the service line
Service Line Length
Enter the length of the service line from the source to the POC
Service Line Max Velocity
Enter the maximum velocity provided by the service line
Source Elevation Change
Specify the change in elevation from the water source to the POC; if positive, the POC is higher in elevation than the source
Water Meter
When a water meter is attached to the service line between the source and the POC, select this option and specify the water meter size
Water Meter Size
Select the size of the water meter from the list, or select Edit List to access the catalog of water meter sizes; see Concept: Using the irrigation catalog
Comment
Adds an informational note to the catalog data
Output
Line Pressure Loss
Displays the pressure loss for the service line, as determined by the service line type, size, length, and max flow
Elevation Pressure Change
Displays the pressure change due to elevation differences, based on the Source Elevation Change parameter
Meter pressure loss
(water meter)
When a water meter is attached, displays the calculated pressure loss, based on the size of the water meter and the Max Safe Flow
Additional Pressure Loss
Enter any additional pressure loss to be included in the Output Pressure calculation
Output Pressure
Displays the calculated pressure produced by the POC, after modifying the Source Static Pressure by considering values specified or calculated in Line Pressure Loss, Elevation Pressure Change, Meter pressure loss, and any Additional Pressure Loss
Service Line Max Flow
(water meter)
Displays the maximum flow at which the Service Line Velocity does not exceed the Service Line Max Velocity
Water Meter Max Flow
(water meter)
Displays the maximum flow rate for the water meter, as determined based on the Water Meter Size and the Source Static Pressure values
Max Safe Flow
Displays the calculated flow rate safely provided by the POC. When there is no water meter, this value represents the maximum flow at which the service line velocity does not exceed the maximum velocity set for the service line. When a water meter is present, displays the lesser value of either the Service Line Max Flow or the Water Meter Max Flow.
Displays the calculated velocity of the service line, based on Max Safe Flow, Service Line Type and Service Line Size
Graphics
Symbol Name
Replace Symbol
Symbol Scale
Attach Tag/Label
Automatically attaches a Tag/Label object to the object. The last selected tag/label for the object type is applied; click the tag/label to edit its properties (see Adding labels to irrigation objects).
Show Pressure
Show Flow
Concept: Creating connected irrigation networks
Creating design zones
Irrigation system warnings
Irrigation settings
Irrigation
Using preformatted reports
