LandmarkLandscape area preferences
Landscape area preferences are set from the Landscape Area Preferences dialog box (see Creating landscape areas). The parameters can be edited later from the Object Info palette.
Parameter
Description
Use Style
From the Resource Selector, double-click a style to apply it, or leave the landscape area unstyled. See Concept: Plug-in object styles.
Convert to Unstyled
Converts a styled landscape area to unstyled for editing; the current values are retained, but all parameters on all panes are set to By Instance to allow editing
General
Name
Enter a landscape area name, which can be displayed in the tag
Tag Display
Displays a tag to the right or left of the leader line
Tag Class
To control appearance and visibility of the landscape area tag, select a class from the list of classes present in the drawing, or create a new class. Select <Landscape Area Class> to place the tag in the same class as the landscape area object.
Tag Line Angle
Specifies the angle of the leader line. Range: 0–360°.
Tag Text Angle
Sets the text angle. Range: 0–360°. To display the tag to the left, specify an angle greater than 90° and less than 270°. To display the tag to the right, specify an angle less than 90° or greater than 270°.
Tag Header
Select the information to display in the first line of the tag; select Set Custom Tag to define a custom tag (see Creating a custom landscape area tag)
Tag Body
Select the information to display in the main portion of the landscape tag; select Set Custom Tag to define a custom landscape area tag (see Creating a custom landscape area tag)
Area Units
Select the units for calculating the landscape area; this is set to the file units by default (see Units), but can be changed
Display tag line marker
Displays a marker at the end of the leader line; specify the marker to use by editing the tag class properties (see Setting class properties)
Edit Components
Opens the Landscape Components dialog box for determining the structure that makes up the landscape area, as described in Creating landscape area components
Plant Information
Specifies the species makeup of the landscape area, as well as how to calculate the plant quantities for tag display and planting plan worksheets; select a Distribution rate or by Percentage
Distribution rate (Custom rate/Fixed percentage)
Calculates plant quantity based on plant distribution rate. As each plant is added to the list of plants in the landscape area, its rate per area or from the center is specified; the percentage of each plant in the landscape area is calculated automatically. Coverage is always set to 100%.
Distribution rate (Custom rate/Custom percentage)
Calculates plant quantity based on plant distribution rate as well as percentage. As each plant is added to the list of plants in the landscape area, its rate per area or from the center is specified, as well as the percentage of each plant in the landscape area. This option allows plants to be merged within the landscape area.
Percentage (Fixed rate/Custom percentage)
Calculates plant quantity based on plant percentage of the total. As each plant is added to the list of plants in the landscape area, its percentage is specified. The plant distribution rate must be the same for all plants in the landscape area; specify the rate and units to use.
Rate
(Percentage)
For plant quantities based on percentage, enter the fixed distribution rate of the plants and select the calculation method for the rate. The percentage of each plant species is set when specifying the plants.
Area Increase Factor
If there is no site model under the landscape area, specify the area increase factor to determine the area value.
Plant list
Lists the plants in the landscape area, including each plant’s distribution rate and percentage of the plant total. The plant order can be changed by click-dragging an item in the # column to a new position; this affects the 2D plant stacking order (plants at the top of the list are drawn over the plants lower in the list) as well as the plant list order in the plant tag.
Add Plant
Opens the Edit Plant Information dialog box, to add a plant to the list of plants in the landscape area and specify its distribution rate or percentage
Add Divider
Opens the Edit Divider dialog box, to include divider text in the landscape area tag. If desired, the divider text can have different formatting from the rest of the tag text. Data tags can also display divider text.
Click-drag in the plant list # column to create the proper order of divider text within the plant list. The Plant/Tag ID of a divider consists of dashed lines, so that it is easy to find in the list.
Edit
Opens the Edit Plant Information dialog box, to edit the selected plant or plants
Delete
Deletes the selected plant or plants from the list of plants in the landscape area
Total %
For a Distribution rate with a fixed percentage or a Percentage calculation, displays the total percentage of plant distribution. The total must equal 100.
Graphics
Randomize plant rotation
Rotates individual plants randomly for a more natural appearance
Randomize plant position
Places plants in random locations rather than in a grid-like array
Plant Diameter Variation
Specify whether to vary the plant diameters randomly, and by what percentage
Plant Diameter Visual Scale
Visually scales the plant diameter by the factor entered, making plants look wider on the drawing without changing the actual plant diameter value
Plant Height Variation
Specify whether to vary the plant heights randomly, and by what percentage
Plant Height Visual Scale
Visually scales the plant height by the factor entered, making plants look taller on the drawing without changing the actual plant height value
2D Display
Border Style
Specifies the type of border for the edge of the landscape area
Standard
Sets the border to a single line
Plant Cloud
Draws the border with a convex or concave cloud shape; specify the cloud billow type and the billow parameters. In addition to selecting the billow size and height, the billow variability sets the variation between the smallest and largest billows.
Plant Line
Creates a freehand plant line border; for a rougher plant line border, specify a short segment length with high segment thickness
Show plants in 2D
Displays individual plant symbols in Top/Plan view. Deselect the option to create a landscape area that reports plants and area with a more generalized appearance that can take on attributes like a gradient or image fill.
3D Display
Select a 3D display option for the landscape area; in 3D views, plants conform to the surface of the site model if one exists
Display the components in 3D
When components have been specified on the General pane, displays the components in 3D section views
Display as 3D polygon
Creates a 3D polygon at a default elevation of 0, which can display a fill color when rendered. Alternatively, assign the landscape area a texture from the Render tab of the Object Info palette.
When the landscape area is to be associated with a site model, select the layer with the site model from the Site Model Layer list on the Object Info palette. The 3D polygon is set to the site model surface; the polygon has no fill in this case, and the plants, if any, are on the site model surface.
Display as a texture bed on:
Creates a texture bed for the 3D representation of the landscape area; select whether to display the texture bed on the existing site model or the proposed site model. If there is more than one site model in the file, the texture bed conforms to the site model that is in the same layer as the landscape area.
Apply a texture to the landscape area from the Render tab of the Object Info palette. The texture set for the Datum component, when components exist and are set to display, supersedes this texture selection. The texture can be edited with the Attribute Mapping tool; see Direct texture mapping.
Select the site model and click Update from the Object Info palette; the landscape area displays as a texture bed on the site model.
Show plants in 3D
When the landscape area contains plant symbols with an image prop 3D component, switching to a 3D view displays the image props, for a realistic 3D view. Plant density is determined by the distribution or percentage specified for the landscape area. 3D loci are placed when the plant styles do not have a 3D component.
The Plant Information pane specifies the plants to include in the landscape area and their distribution. Click Add Plant, or select a plant from the list and click Edit, to open the Edit Plant Information dialog box. Alternatively, double-click an existing row of plants to edit it.
Parameter
Description
Plant selector
Opens the Resource Selector to select a plant style for placement; double-click a resource to activate it
Latin Name/Common Name/Plant/Tag ID
Displays the selected plant’s style information
Rate
If Distribution Rate is selected in the Landscape Area Preferences dialog box, indicate the plant distribution value and units. This distribution value is used to calculate the plant quantity for each plant type in the landscape area.
Percentage
If Percentage is selected in the Landscape Area Preferences dialog box, indicate the percentage of this plant in the landscape area. Using a fixed distribution rate for all plants, the percentage is used to calculate the plant quantity for each plant type in the landscape area. The total value of all plants must add up to 100%.
To save the landscape area preferences as a style, select New Plug-in Style from Unstyled Plug-in from the Style list on the Object Info palette. The landscape are style is saved as a resource in the file, and displays in the Resource Manager and in the Landscape Area list on the Tool bar.
Editing landscape areas
Creating landscape area schedules
