Design SuiteEditing roof objects
Once a roof object has been created, there are multiple ways to edit it:
Edit some parameters from the Object Info palette.
Change roof edge shapes (such as hip or gable) using the Selection tool and the Edit Roof Settings dialog box.
Create cutouts in the roof using the Clip tool or Clip Surface command.
Reshape the roof object using the Reshape tool.
Add an accessory: attic, soffit, or fascia (Vectorworks Architect required).
Roof properties
Changing the roof edge shape
Reshaping roof objects
Adding roof elements to roof objects and roof faces
Creating cutouts in a roof object
Adding roof accessories
Using roof styles
Creating roof components
Roof and wall associations
