Design SuiteSpecifying global grade object preferences
Tool
Workspace: Tool set
Grade
Architect and Spotlight: Building Shell
Landmark: Site Planning and Dims/Notes
The grade indicator appearance for all grade objects in the file can be specified globally.
To set global grade object appearance:
Click the tool.
Click Preferences on the Tool bar. Alternatively, select an existing grade object; click Settings from the Object Info palette, double-click the grade object, or right-click on a grade object and select Edit from the context menu.
The Grade Settings dialog box opens. Click the Global Settings tab and enter the desired settings.
Parameter
Description
Display Settings
Arrow Line Length
Specifies the length of the grade directional arrow, in page units
Arrow Offset
Sets the distance of the grade directional arrow from the grade line, in page units
Grade Definition
Select the type of display for the slope (percent, permille, run/rise ratio, rise/run ratio, or angle)
Precision
Sets the displayed precision for the slope value
Directional Indicator Attributes
Pen/Style
Select the pen style and line thickness for the grade directional arrow. Alternatively, select Class style in the Pen list. The pen, color, style, and marker are then determined by the class attributes of the grade object.
Color
Click the color box to select the grade directional arrow color
End Marker
Specifies the marker type for the end of the grade directional arrow
Opacity (%)
Sets the opacity of the grade directional arrow; drag the slider to the left to decrease opacity, or enter an opacity percentage
Use class opacity
The opacity of the arrow can be set by the class of the grade object
Make All Attributes By Class
Sets all pen attributes by class
Remove All By Class Settings
Removes all class settings for pen attributes
Reshape Setting
Preserve grade if one point is not connected
Preserves the grade of a reshaped grade object, and recalculates the elevation.
This preference works only if at least one end point of the reshaped grade object is not connected to another grade object; the elevation of the unconnected end point is changed. If both end points of the reshaped grade object are connected to other grade objects, the grade is changed and the elevations are preserved to maintain continuity with the connected grade objects.
Analyze Grade Objects
Uses grade objects to analyze the slope or elevation; choose to highlight (in the specified color) and/or select objects that meet the criteria. Specify the criteria to mark.
Calculating and displaying grade and elevation
Concept: Attributes
Setting class attributes
Inserting grade objects
Analyzing grade
